Balloon Text Size
alexp.dsgn
3-Newcomer
Balloon Text Size
Hi folks!
I have one issue that I can't solve on my own, perhaps someone could help me with it.
Since I have to use a different balloon text height from the main text height, I manually change it every time creating an assembly drawing. Is there a way to input an exclusive balloon text height in prodetail file? I couldn't find the necessary parameter there.
Please note that I'm talking about the text size, not the min/max balloon radius.
Thanks in advance!
kdirth
(To:alexp.dsgn)
I could not find one in the Creo 7 list of config settings.  I don't have a list of the hidden settings.
I would suggest creating a mapkey to perform the text size change.
5 REPLIES 5
kdirth
(To:alexp.dsgn)
kdirth
(To:kdirth)
If these are BOM ballons, you could create a custom BOM ballon with the desired text size.
alexp.dsgn
3-Newcomer
(To:kdirth)
Thanks a lot, @kdirth !
In my case, the custom symbol solution works perfectly 👍
KenFarley
(To:kdirth)
I have the "normal" and hidden config settings list (I use them so my text editor will show the hidden options I have set with a distinct text color). There is not  a hidden option, either, for the setting of balloon text.
Thanks for checking @KenFarley 🙂
