Beam Idealization
plandoll
Beam Idealization
In the Creo Simulate Help Center it says the use of beam idealizations is only valid for a ratio of beam height to its length of up to 1/10.
I would like to simulate a part which has a ratio of 4/10. Simulating the part as a solid is not an option.
How does that "invalid" ratio influence the simulation results?
I would also like to know how many nodes/elements Creo Simulate creates on each beam idealization and if this is variable.
Any help is greatly appreciated.
skunks
(To:plandoll)
example (volume vs. beam)
regards
paul
6 REPLIES 6
skunks
(To:plandoll)
regards
paul
plandoll
(To:skunks)
Thank you very much for your fast answer, Paul.
I hope I interpret your model correctly since I see only a difference in the max. deformation value of about +2,3 %.
I attached a sketch of my use case. Is the deformation difference the only deviation resulting from the use of the beam idealization? If yes, that would cause point A and B to displace a little more than they should but due to their identical behaviour the long beam would undergo the same load, wouldn't it?
Best regards
Patrick
skunks
(To:plandoll)
for example as volume (better).
regards
paul
plandoll
(To:skunks)
Again, thanks very very much for your very helpful model!
I hope that this is the last time I have to ask a question concering this topic.
I see that in this case the displacement difference of a solid and a beam model is huge.
Due to the fact that I have lots of these c-profiles connected to each other, I want to use the beams at least for the longest beam. (attached file: example_02)
I attached a comparison between a solid, beam and combination of both (example_01). In this comparison there is huge displacement difference of the mixed beam-solid model and the solid model. But this time the ratio of beam height to its length is valid according to Timoshenko beam theory.
The only possible blind spot I can imagine is the connection between the beam and the solid or is there another mistake I don't recognize?
I would really appreciate your help.
Best regards
Patrick
skunks
(To:plandoll)
hello Patrick,
test as beam-volumen
regards
paul
skunks
(To:skunks)
