Bend editing in Flexible Modeling. Change default Anchor APEX and Bending editing option values.
DerrickVanNieke
8-Gravel
Is it possible in sheetmetal flexible modeling to change the default options when editing a bend to have Anchor Apex active and use "Constant wall Height" as default for Bending editing option.
99.9998% of the time you want to change bend radii of a customer's solidworks/etc... file you don't want the flange to move or become larger. So the current default values creates extra work by having to select options to get the size and position back to normal.
The part dimensions should stay as in the original file by default.
3 REPLIES 3
@DerrickVanNieke
As of now there is option to make Anchor Bend Apex and "Constant wall Height" as default. There is an article stating the same CS313374 and requesting to submit an Idea.
Hi there @Mahesh_Sharma, thank you kindly for your repsonse. do you mean the new 7 build can do it?
because if I look at the article it states:
https://www.ptc.com/en/support/article/CS313374
thank you for your help,
Derrick
Hello @DerrickVanNieke
No, functionality is not available in Creo 7.0. You can submit an Idea
