Bending parts around an assembly
ChristianSmith
I have an assembly and I have a cable that connects one device to another. This cable needs to hug the assembly and fit through a slot, bend around a corner and enter into another hole. Is this possible to do?
1 REPLY 1
There is a module for that . . . Of course you're aware of Pro/CABLE
Short of that, you can create a part that looks like a cable that does all of these things AND is associative. So the answer is yes, it can be done. Using curves and offset surfs, create sweeps to define your cable . . .
