Can anyone help me to understand how can we create bending table of a pipie segment wrt part co-ordinate system in Pro/Piping.
Amit
I give directions for doing this in my desktop instructions here; Desktop Instructions for Piping.pdf
Hope this helps,
Arnold
Hope this helps,
Arnold
Hi Arnold,
In your suggested PDF I could not able to retrieve the Bend location table in drawing. I could able to reproduce till page#14, but how to get the table in drawing.
Can you please throw light on the same.
Amit
Hello Amit.
Place this table in your drawing. This should show the bend information.
Arnold
Sorry Arnold, Could not able to derive the bend information in the table file after placing in drawing.
Attached image is for your reference.
Amit
Did you remember to "Select the “Designate for Report Setup” checkbox", as described in 4.8.4?
Hi Arnold,
I really skipped to check "Designate for Report Setup". It is working fine now.
I have a question, where that Bend table file got saved? And How to retrieve it into the drawings?It worked fine with the table file you shared, but wanted to understand how it worked.
Sorry it took me so long to reply. I've been covered up at work. Save the table file to your hard drive or server, then browse to it when you go to insert into the drawing. The bend information is saved with the piping assembly and is read from it to populate the table.
Arnold
