Best way to make instances of a cable harness?
I'm working in CREO 10, but I'm very new to it after many years of Inventor and SolidWorks.
I have a cable assembly that I made without using the cable tools. I have a PCB, roughly 10" length of ribbon cable doing a 180 turn (modelled as a U-shaped part), and a 2nd PCB. I have 2 locations where I use this harness, and the placement of PCB 1 relative to PCB 2 is about 1/2" different between the 2 location. I'm trying to make 2 versions of the same assembly (since we'll use the same PN for both locations), where the length of legs of the 'U' shaped cable change. On one instance, both legs should be the same length. On the other instance, the legs should be 1/2" different, but still 10" total path length.
Based on googling, it looks like my options might be a Family Table at the Part and Assembly level to select the leg length. But maybe it makes more sense to do a Spine Bend (if I can figure it out) on a straight base part? Or some other approach?
