{Blank Subject 2010-10-22}
bbrejcha
This might be a question for the PTC guys Martin and Jim Barret Smith.
I have a variable connector that has 60 or more pin call outs in RSD. How
can I get the connector to cut and continuation onto a same view and or onto
different sheets.
Some of these military connectors that go into orbit have 128+ pin call outs
and they don't fit even horizontal on a d-size sheet. My customer wants to
do it like they do in AutoCAD and split up the symbol so one part of the
variable group connector is on the left and the rest of the connector is
stacked on the right. Or another sinario would be to split up the extra
long connector onto different sheets. Comments?
Bart Brejcha
*DESIGN-ENGINE|**EDUCATION*
Place the connector with the desired number of pins
Select the connector > right click > Copy
Right click > Paste Shape (not paste)
Select desired location / sheet and place
Select connecter > Right click re-order
Select the pins you would like to show / not show
Jim
