Blend Section to Surfaces
VladimirPalffy
Short demonstration of how to create a feature Blend Section to Surfaces
Best Regards,
Vladimir Palffy
6 REPLIES 6
It's amazing how some features that are not used often by many could easily be forgotten.   Thank you for sharing this great feature that may be overlooked by many.
Best Regards,
Vladimir Palffy
thats great but what if you had to hold 5 degrees on that wall.  you dont always know where the curve would be on the bottom surface.  can you do that with this tool or is there another that you could hold tangent to the top piece and hold angle of 5 degrees down to the bottom surface.
thanks.
You don't forget - you can always create a draft analysis (check draft)
Best Regards,
Vladimir Palffy
nice tutorial
Thanks Steve
Best Regards,
Vladimir Palffy
