I am using Creo Parametric - Release 3.0 (connected) 3.0 M170
Using the blend feature to create a oblique cylinder that has rolled and bend sections, software cannot unfold the bend walls.
Here are the errors that I faced
none
Can you provide a model or an image of the model?
Creo sheetmetal, in general, will unfold bends that are straight, such as ones that would be made by a press brake or a roll.
Usually those that don't fit in that category can be unfolded using surfacing features (not sheetmetal).
An image or the model will likely help us help you.
