Hello @ET_9392213
You're right, the UI changed in Creo Parametric 7.0 which does not propose anymore access to the Transparency Options drop down box (previously proposed in earlier versions):
Hope this helps
Serge
Hello @ET_9392213
Hope this helps
Serge
Thank you very much for you quick answer!
