Bloody weld symbols...
RV_5434567
I'm looking for a way to make a weld symbol that looks like this:
The closest that I found is a symbol, modified years ago by a colleague who is no more, that looks like this:
Problem is it's just not very accurate - reinforced half-V should be reinforced half-Y.
I've tried to use the symbol editor to modify a copy of this thing, but to no avail. I don't know what lines to change/add and how this will work in symbol properties. Ideas anyone?
4 REPLIES 4
Oops, added the wrong sym-file to the original message.
This is the one.
Found the edit button and replaced the file in the original message.
You may try creating a new symbol.
Details are in article:
CS21098
Apparently "You need to add/renew your maintenance to view this article"
Is PTC begging me for money? Cuz I'm not in charge of licenses around here...
Articles are viewable, if you are in active maintenance and web account is verified. If you are not in charge for licensing ask your IT or respective team to check details.
