Blue Screen of Death
abowman-2
Hi all,
I'm a mechanical engineering student who uses Creo 3.0 (M110) for designing for my school's Formula SAE team, as well as in some classes. I built a new computer with the intent of using it to model and run FEMAP/Nastran simulations on for various projects.
Parts in it:
AMD Ryzen 7 1700 procesor
Gigabyte AB350M D3H motherboard
32GB Corsair Dominator Platinum ram
AMD Radeon R9 290 graphics card
Samsung 850 Evo SSD
650 watt EVGA power supply
Symptom: Every time I try to launch Creo parametric, on a very fresh install of Windows 10 Education edition, I get a blue screen of death with an "unexpected kernel mode trap" error to go along with it. I have all the most recent drivers from Gigabyte's website, and really can't figure out why Creo and nothing else causes a BSOD within seconds of opening up. I get to the main screen, and I don't get any script errors (which I've seen a million times when first opening Creo) eiteher.
I have stress tested ther CPU, memtested the RAM, and the GPU is an older part that has never had real issues (I've tried some other GPU's to no avail as well).. I know this is a very recently launched CPU architecture, and that might be contributing to the problem.
Any help would be appreciated!
12 REPLIES 12
StephenW
(To:abowman-2)
A TS Bulletin has been posted on the PTC Support Website:
Windows 10 Creators Update (1703) may cause blue screen system shut down with Creo Parametric 3.0
Amit
Login first and then click on the update.
If you click on the link and then login, you get:
Thanks, Dale
StephenW
(To:Dale_Rosema)
You're on the highway to ... a sandstorm???  This is what west Texas looks like just before the duststorm blows in!!
Link works fine for me: https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS000261077
PDF document with the contents of the page in attachment.
KDX
2-Explorer
2-Explorer
(To:abowman-2)
Mat
(To:KDX)
The link to the update (also posted on CS261077; https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS000261077) seems to be dead.
MartinHanak
(To:Mat)
KB4022716 was replaced by KB4025342.
Martin Hanák
Mat
(To:MartinHanak)
Thanks.
( https://www.catalog.update.microsoft.com/Search.aspx?q=KB4025342 )
bsod is now resolved, but somehow the icons within windchill are not loaded anymore:
MartinHanak
(To:Mat)
Please show the problem to PTC Support.
Martin Hanák
Mat
(To:Mat)
had to delete internet explorer's cache.
Everything is fine now.
Thanks!
