Hello everyone,
I’m trying to insert a brachistochrone curve into a 3D model in Creo Parametric 10 on the XY-plane using the “Curve from Equation” feature. Unfortunately, I can’t seem to get it to work… The only result I get is a short straight line segment.
The formula for the brachistochrone curve should be:
R = 4.8 (own shoosen radius)
in Creo, the trigonometric functions use degrees, not radians.
Thanks for your quick reply Pausob!
OK, that's good to know, but what should the equation be then?
you can leave the equation as is, just increase the range from 0 to 360.
Hi! Try this
Tmax = 1
X = R*(T*pi*2-sin(T*360))
Y = R*(cos(T*360)-1)
Thanks Vronov, this works!
