I´m using Creo 2.0 I have a pipe which runs in the x axis, and in some part of this pipe I want to connect another pipe that runs in the Y-axis. Can I make a whole in this pipe, and so connect another pipe to the first one? I have been trying to do it with branch but I can´t manage it.
Thanls a lot!
Best regards,
Edna
When you create solid pipes from the pipelines, holes should be added automatically at branches (if you have not entered a T-fitting at this location).
