CREO 10.0.0 - Standard Tapped hole, Thru Thread depth setting missing?
mcbooya
8-Gravel
Just started using CREO Parametric 10.0.0..... and notice that there is no option to set a standard tapped hole to have a thread depth through the entire length of the hole. For example, in part modeling making a hole-set references - set Standard type - set to thru-all depth setting- add tapping - go to Shape tab - the only option for thread depth is a blind specified value. No Thru Thread option.
Chris3
(To:mcbooya)
Are you clicking on this icon?
Chris3
(To:mcbooya)
When they added the "to reference" button they made it a drop down. Click on the blind depth button.
mcbooya
8-Gravel
(To:Chris3)
Mine actually does not have those options. The drop down is there but it is just blank without options to choose no matter what hole depth setting I use.
Chris3
(To:mcbooya)
mcbooya
8-Gravel
(To:Chris3)
Thank you, that was my problem is I was using the drop arrow on the value, not the thread icon. I didn't even notice that other one.
