I am working in Creo 10 Cabling of which I am still in the early learning phases. I am able to route multiple cables in my assemblies but now I'd like to know if it is possible to create generic Wire Looms that would surround them along their paths. I would prefer to create this before any routing so that I could use it to follow its route when creating new cables in my harness. Is this actually done in "Sheathing" in the new cable routing window option or maybe as a spool and if in a spool, how do I enter the ID diameter as well as the wall thickness?
Thank you.
You are in the wrong forum.
PTC has two CAD systems: Creo+ and Creo Parametric and Creo Elements Direct.
Which makes it confusing.
More, for Creo Elements Direct:
- The 3D software name is Modeling, and
- The 2D software name is Drafting.
For Creo+ and Creo Parametric, use only this tab:
You should move your post to this community to have a better chance to get an answer.
To move your post, click on the three vertical dots on your initial post and click on "Notify Moderator".
As per @Kotom-Eng's reply, I have moved your topic to the Creo+ and Creo Parametric discussion board.
Best regards,
Hi @Charles421SD
Thank you for your question.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Best regards,
