CREO 3.O ISSUE WHILE CREATING FAMILY TABLE PART.
dyadav
I have importing dxf file and creating part and instances from that part. Once I create that Part instances from Family Table, I surprised that Imported curve In Parent and child has VANISHED and all the feature has become failure mode.
Hey all PTC champ please refer attached images for the same if possible give me the best solution for that.
If I work in Creo 2.O it is working properly.
dyadav
(To:MartinHanak)
Martin,
Need to check with my customer, if they give the green signal for uploading the file then I defiantly upload the file. as it is at critical level, please suggest if any method. FYI... just for information, By yesterday I got some tricks like before opening the family table part if I verify that part it opened perfectly BUT only that curve which I imported is vanished.
7 REPLIES 7
MartinHanak
(To:dyadav)
Dinesh,
if you cannot upload your file, then it is difficult to find the source of the problem.
Note:
It is strange, that Curve From ... feature has Feat # 69, when model works (generic) -AND- Feat # 59, when model fails (instance). Where 10 features has gone ?
Martin Hanak
Martin Hanák
dyadav
(To:MartinHanak)
Martin,
MartinHanak
(To:dyadav)
Dinesh,
maybe ... the curve was included in some layer automatically and that layer is in hidden state. Therefore the curve is not visible in graphics window.
Martin Hanak
Martin Hanák
dyadav
(To:MartinHanak)
Martin,
Thank you for your reply...
Issue has been resolved by latest Date-CODE.
MO60
StephenW
(To:dyadav)
In your PDF, you said this was stopping all your work. You really need to open a support ticket with PTC and escalate it to critical.
dyadav
(To:StephenW)
Stephen,
Already raised case to PTC India. They are working on it.
Thank You
dyadav
(To:StephenW)
  Please refer below update from PTC Case
"This is with reference to case, regarding There is a problem in Creo-3 while working with imported file (DXF) The DXF file is getting vanished during working and the related features made from the DXF is getting failed.
As discussed over phone, please download the data on local drive and then test the issue. If the issue is still reproducible, please send me the data and steps, I will take a look into it."
