This may be a silly question:
- I recently started using CREO at work. I had a PC when I first got at work. They switched me out to a laptop.
- I thought I remembered that CREO Versioned File Extensions (i.e. .1, .2, ... .50, .51) showed up in Windows FIle Explorer. Am I crazy?
- I need to know the latest versioned file since this is how we manage rev control at our work - not Windchill here.
- I remember the versioned file extensions showed up on my PC - now with my laptop I see nothing.
- Is this a Window File Explorer setting - or a CREO setting?
- So, when I have to upload a specific versioned file I have to use Windows sort by date to see latest.
- Please help me see the actual versioned files in Windows Explorer or open/save dialog box.
I found it my bad - I looked through Folder Options in windows. It's the hide file extensions of known files:
This took me 30 minutes to resolve. Now I know going forward.
Windows file explorer settings:
Within Windows functionality, the File Explorer is an important tool, granting you access to and dominion over your operating system’s array of files. Moreover, this versatile utility accommodates the revelation of file extensions dwelling within your computer’s precincts. To undertake this venture, adhere to the following guidelines:
