Only if I open in my session the source drawing and after I regenerate the target drawing, the problem will solve.
But taking in to account that after the check-in the cad worker will retrieve only the target drawing, so the problem will reflect after in windchill.
PTC Checked for the issue, and they solved Article - CS391057
The solution will be implemented in the next datecode.
please ask PTC Support.
Done
