不用每次都按F11.
Are you asking if it is possible to open Creo 4.0 in full screen mode, by default?
你问是否可以在全屏模式打开的Creo 4.0 ,默认情况下?
Amit
yes.是的
You can set the config option windows_scale to 1 or open_window_maximized to yes or reserved_menu_space to 1. You can find further information via the following article:
CS31876 - 在 Pro/ENGINEER, Creo Elements/Pro 和 Creo Parametric 中,如何设置软件窗口打开时的默认大小
If you don't have an account, you can create one here.
Amit
Were you able to see the article and did that help answer the question?
Amit
按上面设置,还是不行,打开不是全屏的。
