I have been trying to add an excel table into a creo drawing and when I import the csv file into the drawing the data is separated by commas and I get only one-column table. Does anybody know how to fix this so that I get all the columns and a table that looks like to one I have in excel?
Thank you for your help.
@BC_10219589 wrote:
Thank you for your answer, however, I can't paste excel cells into my creo drawing (I am using Creo 7, 0.7.0)
do you know why this happens?
Thank you,
did you apply setting from https://www.ptc.com/en/support/article/CS355947 ?
Creo 7.0.7.0 & Excel 2016 on my PC works as expected. See video.
on my PC I applied setting from https://www.ptc.com/en/support/article/CS355947 .
In Creo 9.0.0.0 I am able to:
I do not need to export/import csv file.
Thank you,
Thank you,
Thank you very much, now it works. Do you know if there is any possibility of changing the font size and table widht/height? (once it's an excel table) The table I want to add is a very large one and I'm not sure if using this option I will be able to make it fit in one sheet and would like to control those parameters.
double-click the table ... Excel UI opens ... then do what you need.
