CSYS ALWAYS VISIBLE
cspinelli
CSYS ALWAYS VISIBLE
hello everyone,
is there a way to show csys always visible as in Creo View?
thanks
kdirth
(To:cspinelli)
Here is an Idea for what I believe you are asking for.  Vote for it to give the Idea your support.
make current World-CSYS visible in Creo Parametric... - PTC Community
8 REPLIES 8
aputman
(To:cspinelli)
I guess you could turn on CSYS display and then don't ever turn it off. 😁
mkajdan
(To:cspinelli)
Does turning this option on do what you are looking for?
display_coord_sys    yes
aputman
(To:mkajdan)
That does the exact same thing as turning on CSYS display.  That check box and the CSYS display button are linked.
mkajdan
(To:aputman)
But when you start a new session of Creo, it will already be on.  There will be no need to select the CSYS display button to turn them on.
config.pro option ... display_planes yes
However, you have to take into account that CSYS can be in the hidden layer.
Martin Hanák
cspinelli
(To:cspinelli)
thanks all but maybe i've phrased the question poorly... i meant if there is a way to show orientation of first csys in left lower angle as in Creo View.
In Creo Parametric there is no csys like in Creo View.
Creo Parametric uses Spin center which can be placed on model geometry.
Martin Hanák
kdirth
(To:cspinelli)
