Hi experts,
can we add against each thread size? (i.e. a parameter called DEPTH_RATIO),
this is require b'cos considering the the drill depth is 3x of drill size
and thread depth is derived from drill depth x depth_ratio,
we require thread depth as per ISO 1179-1 for hydraulic port.
You could create a user defined feature using the hole feature with relations to control the depth.
Refer to this link for introduction to UDF:
About User-Defined Features (ptc.com)
