We recently upgraded from Creo 6 to Creo 8.0.7.0. The cabling option is missing on the Applications tab. How do I get the cabling option activated in Creo 8. Thanks
I am dumb. I was trying to find it in a part file. You have to have an assembly open.
I would laugh at you but I've made the same mistake with the routed piping application. Always takes a minute to work these things out in the old noggin'
Thanks for posting for those who would run into that same road block... 🙂
