Hi
I have to calculate one of the dimensions (Inside height for main body) for the Vial and the volume is given.I have attached a file which shows a drawing of the vial which the volume has to be calulated and product family table details of other vials.
The question given is:
I am able to calculate the height no problem using the realtions tool by setting up two equations
but, I am struggling to use the family table to find the height for other vials. So far it seems the total volume is being set as a parameter, which therefore gives me the same value for all other vials.
Is there a way to correct this so that setting up the realtions will let me use the family table correctly.So to find the dimension(Inside height for main body) I would only have to create one inital vial rather than twenty vials.
Any help would be much appreciated please !
u need use BMX, 行为建模。
