Can sketch be saved as DWG?
SkyKing
I go to save as, and try to save as DWG and it does nothing.
Hi Sky,
This functionality will be available in Creo Parametric 4.0.  For now, use one of the two following workarounds:
  1. Fastest way would be creating a new format file using the saved section file and export to DWG/DXF
    1. File > New > Format > OK
    2. Choose Empty with Section under template Options in New Format dialog
    3. Hit Browse and select the saved section file (*.sec)
    4. Hit OK to create new format file
    5. Export the format file using File > Save as > set type to DWG or DXF
  2. Create a sketch datum curve importing the saved section file, create a new drawing for the part and export the drawing to DWG/DXF
Amit
People pay $$$$ for a basic functionality that is there, but yet not available until Creo Parametric 4.0. WOW!
So how do you do it in Creo 4.0 ?
