Can't blank vertical line which divides columns in a table
marcstewart63
Hello everyone,
I am attempting to do something that I have done before, but cannot seem to get to work today. I have a table on a drawing that a user wants to add an additional row in. The table is just a text table and does not contain any repeat regions. The table has a column displayed that is actually (2) columns with the vertical line separating the columns blanked (see top row in picture below). The user wants to add another row and have it appear just like the row above it. I tried to blank the line in the table separating the two columns to make it appear as if it were one column.
[cid:image001.png@01CAF8FA.4FC23300]
As you see in the bottom row in the picture above, there is a vertical line separating the 2 columns, and nothing I have tried has allowed me to remove it.
In the past, I think have done the following to blank lines in tables:
Select #Table > #Line Display > #Blank > Select the line and it disappears
That pick stays grayed out no matter what I select in the table.
[cid:image003.png@01CAF8FB.E9674760]
I even created a new table to see if I could blank lines within it and I can't.
Anyone able to tell me what I am doing wrong. It appears that something is not working the way it has in the past.
Running WF3 M220 with Windchill 9.1.
Marc
Because We Care
[cid:image002.gif@01CAF8FA.4FC23300]
Marc Stewart
Senior Design Engineer
Midmark Corporation
60 Vista Drive (Plant A)
Versailles, OH 45380
Marc,
You can probably merge the two cells together that are separated by the vertical line to make it look like the top row. TABLE --> MERGE CELLs
James
Have you tried just merging the cells?
