Can't copy parameters in tables sometimes
gbon
I've made drawings with several tables that show parameters and have to
duplicate them.
For example, I'm making a simple table of 3 cells:
- &model_name
- &dwg_name
- &pro_mp_mass
So I have the values of the 3 parameters in my table.
If I copy and paste this table, the new table is containing this
- model_name:1
- &dwg_name
- pro_mp_mass:1
So, for first and third lines ''&'' symbol disappear and '':1'' is added.
Then, only the second line continue to display parameter value.
I get this even if I copy and paste the table in the same drawing.
Anybody knows what happened and how to do for continuing having parameters
values?
2 REPLIES 2
BenLoosli
(To:gbon)
What version and build are you using?
Have you tried to save the table and then import it instead of copy/paste?
dgschaefer
(To:gbon)
Is this a multi model or assembly drawing? The :1 is the session ID for the part that the parameter comes from. The middle parameter calls from the drawing, so no session ID required. I don't think the session IDs are added if there's only one model in the drawing.
LinkedIn
