Can the circuit board, rigid board and non-rigid board be converted to each other in ECAD assembly?
Subject: Can the circuit board, rigid board and non-rigid board be converted to each other in ECAD assembly?
I am using Creo Parametric Release 5.0 and Datecode5.0.6.0
For the circuit board assembled by ECAD, the engineer converts the original rigid board into a non-rigid board, so how to convert the non-rigid board into a rigid board? Or is this conversion possible?
In simplified mode, you can get and send incremental IDX files only if the board is rigid rather than flexible.
Here are the errors that I faced
Translated with Google Translator by Hedy Jin on Jun 10th, 2022
Subject: ECAD装配中的电路板,刚性板与非刚性板之间可以互相转换吗?
对于ECAD装配下的电路板,工程师将原来是刚性板的电路板转换成了非刚性板,那么如何再把该非刚性板转换成刚性板呢?或者说这种转换是可行的吗?
在简化模式下,只有当电路板为刚性电路板而非挠性电路板时,您才能获取和发送增量 IDX 文件。
