Can the surface of the model retain the colour after draft check
  • February 28, 2015
  • 4825 views
Once I have done draft check, will the colour remain permenently on the model surface, even after we get out of draft check option.
Kindly give the solution.@
I have seen some bugs in this regard with Creo 2.0. Are you wanting the colors to remain or do you not want the color to remain?
Thanks for the response. I want the colour to remain on the model as colour which we give on model surafces.
Analysis surfaces are a special "overlay". This is similar as the curvature where you can save the analysis color but it not a appearance color.
I think it would be great if we can convert the overlay to a texture image.
