There is one specific command that I would like to have copied on my toolbar. This command is found in the Pro-Mold extension and I'd like to copy this into the base seat of Creo.
The icon I would like to copy over would be the Silhouette command. I never use the Pro-Mold assembly style template because it adds complexity and time to our process.
If the silhouette command was available in part mode it would greatly simplify our process of getting a good profile without having to go back and forth between interfaces.
I know this is possible to do because we have received a Creo part model that has a true silhouette operation within it.
Here is what you need to create the silhouette curve on a part - it is a UDF.
Please see attached
Please see attached
Charles: I have no idea how you did this but appears that this works perfectly. Thanks a lot for sharing this!
This would be the 1st time that I've ever did anything with a UDF.
I guess one question that I would have is where would you save an UDF? This didn't work until I placed it inside my Working Directory. Would there be an intelligent location of UDF files? Can you set a retrieve path?
This is very helpful, thanks again!
You need to set a path in your config.pro (and also create a folder to keep your UDFs
This little gem came from my past life - we had a person that did quite a few mold designs and he came up with this.
Charlie Price
Excellent!
I'm really glad I asked.
Thanks again for your help!
