Hello ,
can we automation line Break option in Creo drawing so that we dont have to do it one by one and there are lot of such dimensions in drawing which are overlapping. If there is a mechanism which can detect overlapping dimensions and provide line beak can save lot of time in drawing
Hi @RR_10658669
As of now, there is no config option to enable Break as default. I am unable to locate any Idea, you may submit a new one.
Thanks.
I think that you have chosen the wrong forum.
You'd better try there::
Success
I don't think there is any automatic line break options.
Hi @RR_10658669
Thanks.
What you're trying to do is incorrect per ASME Y14.5-2009, paragraph 1.7.2.1 and Fig. 1-11. Extension lines should ONLY break for arrowheads and text.
