Can we change the thread size created by hole feature using relation?
ruk
I want to change the thread size from M8 to M10 when the size of component increases. Currently I created two separate hole with M8 and M10 and activating it using pro-program when matches with criteria.
Is there is any other option by using relation.
If anybody knows please help me
TomU
(To:ruk)
Not possible using the standard hole feature. You could instead create your own custom hole features (and note) and then control these.
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS139002
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS43933
TomD.inPDX
(To:TomU)
Looks like a specification oversight... works to specifications because there are none
Can't pro-program pick up any named size from the table in a If loop?
