I want to change the thread size from M8 to M10 when the size of component increases. Currently I created two separate hole with M8 and M10 and activating it using pro-program when matches with criteria.
Is there is any other option by using relation.
If anybody knows please help me
Not possible using the standard hole feature. You could instead create your own custom hole features (and note) and then control these.
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS139002
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS43933
Looks like a specification oversight... works to specifications because there are none ![]()
Can't pro-program pick up any named size from the table in a If loop?
