Can we do cloning of creo assembly in creo ?If yes what are the requirement?
What do you mean by "clone"?
An exact copy can be created by performing a backup. All file names are the same.
A copy with new names can be created by Save A Copy. You give a new name to the assembly, then in the Save A Copy window you can give a new name to any of the components in the assembly.
