Cannot edit KEs after switching to Simplified Rep
OS_11014878
Hello everyone,
after I exclude the display of individual components using the Simplified Representation function, I can no longer edit KEs until I close and reopen the session. How can I, for example, edit sketches again?
It happens when I exclude a Copy-Geom.
Q1: No.
Q2: No.
Q3: I can, but I found the problem.
I can edit sketches or extrusions after changing the Simplified REP to Master.
7 REPLIES 7
Sorry, but I don't know what a "KE" is. Is it an abbreviation in German for something?
Konstruction Element = Feature
Martin Hanák
Q1: Can you edit definition of Skizze 1 and Skizze 2?
Q2: Is Skizze 3 dependent on Externe Kopiegeom?
Q3: Can you upload your model?
Martin Hanák
Q1: No.
Q2: No.
Hey, thank you.
It seems that the solution wouldn't work, unfortunately it's still greyed out.
Edit Definition and Insert Here are not available while a Simplified Representation. means that you cannot redefine feature, when simplified representation is opened.
Martin Hanák
