Chamfer problem
jdriscol
Chamfer problem
Hey Suganthan,
Is it a true cylinder and not the end of a curve? The tube end surface needs
to be square to thetube to dimension toit.
jd
ps buddy..., Are you doing one of those jobs that used to be done in America?
3 REPLIES 3
love your desktop...
Laura Woodward
Senior Mechanical Engineer
Saab Training, LLC
Orlando, FL
(407) 281-3012
Try creating revolved cut instead of chamfer. It also gives you more control.
Jurij Škraba
Research & Developement Department for Hydromechanical Equipment
Litostroj Power | Production of Power Generation and Industrial Equipment |
A revolve won't work in his situation, the chamfer is not on a plane perpendicular to the cylinder's axis. A variable section sweep might be a better choice and would easily do the job.
Doug Schaefer
LinkedIn
