Is there a way to move the leader to the text inserted above a geometric tolerance? I have some callouts that are additional text added above the callouts. I also have some callouts that are a geometric tolerance added to a dimension. I would like to move the leader on both of these. I have tried the @O that can be done on multi line text but this is not working. I am using Creo 2 M080.
Thanks in advance!
