Change name of axis labels of coordinate systems
vlincent
Hello all,
I have a question regarding the axis labels of coordinate systems. I want to explicitly show that the axes of the coordinate system indicate the positive sides, with a + sign. For example Y+ or X+. Is it possible to edit the names of the axes labels. Or is there a option which I could check to show the + sign in the axis labels?
Kind regards,
Vlincent
KenFarley
(To:vlincent)
I'm about 99% sure the answer is "no". The axis labels are "hardwired" into the program, as near as I can figure, pretty much in common with every other CAD program I've ever used.
This is correct.  It is not possible to rename the csys axis names.
