Change the Dragger's position
Hi forum,
is it possible to change the location/reference point of the Dragger?
Sometimes you need to rotate a part about another axis than the one where the dragger is located.
So is there a way to re-position the dragger, before actually moving/rotating the part?
It doesn't seem to work in Creo View the way it can be done in Creo Parametric.
VeqTorAnswer
Aaaah! I've just seen that the "Select CS/Pick from Geometry" window allows you to click on any part of the entire model and set that part's axis as the rotation axis of the selection!
That is great, and solved 🙂
Mahesh_Sharma
22-Sapphire I
@VeqTor
I think article CS42111 will help.
VeqTor1-VisitorAuthor
Thanks, but I believe that this article is about Creo Parametric and not about Creo View.
VeqTor1-VisitorAuthorAnswer
