Changing Dimension Tolerance Mode
msteis
I'm kind of stuck with this as I haven't ever used it. In Creo 2.0, how do you change the tolerance mode on a particular dimension as shown below? My option is grayed out.
Matt
ScottWyatt
2-Explorer
(To:msteis)
There is a config.pro option and a drawing detail option called "tol_display". I recommend setting the default to both of those to "yes".
msteis
(To:ScottWyatt)
I'll give it a try Scott. Thank you.
Matt
