Does anyone know how to chance the mass properties of an object from tonnes to kgs?
The old way
Edit --> Setup... --> Units
The new way
File --> Prepare --> Model properties
Then look for the units at the top of that dialog (second option???)
The old way
The new way
Thank you - I used the new way in model properties and changed the units.
Were you able to change the units as suggested?
Yes I got there - I mistakenly was trying to opem the mass properties button when it was the units I had to change.
Easy when you know how!
