Changing a linestock
ptc-1942539
2-Explorer
This is a non-spec driven piping question, if that matters.
There's been a design change, requiring the tube size to increase. This requires a change in the linestock. I have read in the new linestock, and used the modify option in the piping module to select all the segments in the particular tube in question, and change them to the new linestock. I can then delete the old linestock without losing anything. However, when I go to create the bend machine/bend table data, it is still carrying the bend radius from the original linestock. I've tried everything, regenerating the part, skeleton, and the assembly. Nothing works. Thoughts?
Kurt Wolko
I know I'm a little late with this.
You have to "Modify"> "Corner Type"; then select every corner, click OK, then change the radius, click OK, then regenerate.
Hope this helps,
Arnold Collett
