Characters (") in repeat region relations
Ketan_Lalcheta
I am able to set relations in repeat region as below:
if asm_mbr_name == "PRT1111"
CAD_SAP_PLM_DESC = "42 Die Components"
endif
I would like to understand how to use (") into value of CAD_SAP_PLM_DESC. My scenario is to set value of 42" Die components. As soon as I put below line in relation, It does not work:
CAD_SAP_PLM_DESC = "42" Die Components"
endif
Thank you in advance.
Regards
Ketan
CAD_SAP_PLM_DESC = '42' +'" ' + 'Die Components'
Need to change the type of container, in otherwords, I swapped the double quote to a single to capture the text fields so that I can capture the double quote as text
7 REPLIES 7
Instead of using ' or ", can I use another character to type
CAD_SAP_PLM_DESC = ¿l'arbre mesure 42"¿
to avoid writing
CAD_SAP_PLM_DESC = "l'arbre mesure " + '42"'
the desired result is (l'arbre mesure 42")
Thank you
Mathieu Paillé
BenLoosli
(To:MatPaille)
No, it is coded that strings are designated with a ' or ". You can use the ' to designate the string and then use the " for the inch symbol within the string.
CAD_SAP_PLM_DESC = 'l'+"'"+'arbre mesure 42"'
single quote around the l, then double quote the apostrophe and single quote the remainder of the string.
Patriot_1776
(To:BenLoosli)
@BenLoosli  Are the ' and " interchangeable and function exactly the same then?  I've currently been using the ", as in "," to put a comma in.
Grazie!
Frank
BenLoosli
(To:Patriot_1776)
Generally they are interchangeable. I prefer the single quote for strings as it is a single key instead of 2.
As in this example, I had to use both. The single quote was needed to allow the double quote to be accepted as part of the string. The double quote was needed to accept the single quote in the string. I did try to single quote the apostrophe and it did not like the ''' combination.
Patriot_1776
(To:BenLoosli)
@BenLoosli
Hmmm, by " I didn't type 2 ', I simply used a single " key.  Does that matter?
BenLoosli
(To:Patriot_1776)
What I meant was that to get the ", you need to press the shift key with the quote key.
By using the ' for strings it is only 1 key and quicker.
If you did use 2 single quotes, the editor would complain about unmatched or illegal characters.
