Checking assy for errors
sroberts-2
Hi there
is there a easy way to check in assembly where I have errors on components with missing placements
just wanna save time instead of going though all the components and checking them
thanks
If you have any missing placement parts then your assembly will throw errors and is not completely regenerated.
You will notice a red dot indicating this and also the part will be highlighted in red in the model tree.
You can also use the model-check to deeply understand if and where there is something wrong.
You can use the model tree search/filter command to do this.  Select "failed items" from the pull-down list at the top of the model tree.  Then click the "funnel" icon to the right.
This will highlight failed features as well as failed components.  So you may want to exclude features from the model tree if you're only interested in finding component placement failures.
