Choose a Label: Cabling Design not there
Yogesh.T
I do not see a dedicated community for Cabling Corner. Can PTC add that? or where to look for if already there? Thanks!
tbraxton
(To:Yogesh.T)
Cabling is part of Routed System Design which is covered under 3D part and assembly design currently. Routed system design is the appropriate label for cabling/piping.
Involute Development, LLC
Consulting Engineers
Yogesh.T
(To:tbraxton)
okay. Understood.
So piping also comes under Routed System Design? Sweeps, Trajectories, curves also can be used for routing, Are they in the same domain? I am ok to dig in Routed System Design, but it definitely should help me better find, be it:  Routed System , Cabling specific. 🙂
Hi @Yogesh.T,
I agree with @tbraxton. I have updated the label on your topic and Routed Syst. Design is also included.
Catalina
PTC Community Moderator
PTC
Yogesh.T
(To:Catalina)
Sweet! That Helps . Thx
