I have recently downloaded CREO 1.0 educational edition and can not draw anything yet because the browser in creo will not close. Does anyone know how to close the browser? the excape button and browser button do not close it. I once did have it closed but there were no datum planes even when i chose to view them. Any advice?
Hi
You can see a black X at extreem right of the (browser bar)screen to close the browser
But you need to go to Part or assembly mode to see the datum planes
Click the New and choose the type(Part) and name
Now I think you can see Datum planes
Regards
K.Mahanta
The black X, circled in blue, does not close the browser on my screen. The tab, circled in red, to the right of the browser works for me.
I suspect Kshetrabasi is right about you not having begun a new part file, yet. Even without a part file open, you can click the datum plane on/off button, but nothing will happen.
The "x" in the top right doesn't work to close it. Also the button on the side is not there.
Hi
If you are in creo you will not get that option shown in red by Kevin
But the X works for me(But do not work for you)
But you do not need to worry
Because you can anyway go to part and start your work
Regards
K.Mahanta
so there is no way to create a mapkey that toggles the display of the browser now huh?
The original post (from a year ago) referred to Creo1. In Creo 2 there's a small button in the lower left for toggling the browser open & closed. Looks like the earth with a ring around it.
nice, thanks Doug!
