Combined Views - a quick overview
TomD.inPDX
This quick overview of Combined Views is intended to show where to find the relevant buttons and UI's.
Attached is a Creo 2.0 zip file of the assembly depicted in the video for reference.
Video Link : 3760
Please feel free to add to the discussion or ask questions as they arise.
http://communities.ptc.com/servlet/JiveServlet/download/106642994-48092/photo3801_orig.jpeg/CombinedViews.JPG
7 REPLIES 7
Link to the video page: Video Link : 3760
The You-Tube version will play at 720 resolution for a bit clearer image if you like:
Is there a config option to always display the combined views when launching Creo 2.0 instead of having to select Views / Manage Views / Display Combined Views in every session?
I'm thinking of creating default states in the template for my users and would like the combined views/states to always be visible.
Johan Andersson
Try display_combined_views yes in config.pro
Aaah of course...
I was looking for something with "states". My bad but thanks Antonius.
Do you happend to know if there is a config option for the drawing to remove the prompt "select combined state" when adding a view to the drawing. Yes - you can check the box "Do not prompt for Combined State" but you need to do this every session. Should be a config option for this but can't find it.
/Johan
You're out of luck there... see PTC Document - CS37903 if you have access.
Seems silly for the S/W to not check and see if any of the models even have a valid combined view state before asking, huh
Sorry for late reply but have been home sick 😞
But thanks again for the help. And yes it's quite annoying with this window popping up every now and then.
/Johan
