Combined state/Simplified Representation
SleepyDog
I have a drawing in which I want to show an isometric view of a gearbox.
I want to hide one of the castings to show the internals so I can insert a balloon to identify some of the components.
If I use a combined state or a simplified representation I can achieve the view I want but It won't allow me to display the balloons in that view.
I know it;s possible to achieve the result I want because I've seen it in another persons drawing.(who's now left the company).
Any suggestions please?
Andrew
Insert the ISO view of the same model and Rep used to create the BOM baloons. Then "Blank" the parts that you don't want to see.
Randy
6 REPLIES 6
Change this config option to 'yes' and see what happens: allow_refs_to_geom_reps_in_drws. Let us know, I haven't tried it.
-Kevin
Thanks for your suggestion.
Mine was already set to yes so it I tried it both ways with no success.
Regards
Andrew
s.iyer
(To:SleepyDog)
Personaly I would use an offset cross section so that the cross sectional view is shown in the isometric view.
Alternatively, a simplified rep can be created. The repeat region can be to the simplified rep in which case the Bom Baloons would not list the casting. Try it out.
Patriot_1776
(To:SleepyDog)
If you have a repeat region in your BOM, you'll have to set the desired simplified rep as active before you insert it, and then "Fix Index" to get the balloon numbers to match your original BOM, which I'm assuming was inserted with the Master Rep active 9thus containing ALL the parts). Then you can just move that BOM off the field of the dwg so it won't print or PDF.
Randy
SleepyDog
(To:J1SRC)
Thanks Randy, worked a treat.
Regards
Andrew
