Community Tip - If community subscription notifications are filling up your inbox you can set up a daily digest and get all your notifications in a single email.
X
I have a series of parts in an assembly of a few hundred parts and I need to check to make sure that the common name matches the file names because ghost files are being created when these don't match. Is there a way to view this other name opening each part and selecting rename? Any way to batch file this process?
Also, does the common name need to contain the .asm, .prt, and .drw extensions?
Thank you
Ryan Crisp | Senior Mechanical Engineer
Priority Designs 501 Morrison Rd. Columbus, OH 43230 (614) 337-9979 www.prioritydesigns.com This thread is inactive and closed by the PTC Community Management Team. If you would like to provide a reply and re-open this thread, please notify the moderator and reference the thread. You may also use "Start a topic" button to ask a new question. Please be sure to include what version of the PTC product you are using so another community member knowledgeable about your version may be able to assist.
